Displays the PIM snooping configuration for a VLAN.
| vlan_name | Specifies a VLAN. |
Disabled.
None.
The following command displays the PIM snooping configuration for the default VLAN:
* sw1.79 # show pim snooping "Default" PIM Snooping ENABLED Vlan Default(1) Snooping DISABLED
* (pacman debug) sw1.81 # show pim snooping PIM Snooping Enabled <S,G,RPT> Prune Accept Vlan PIM Snooping DR #Nbr l18 Enabled NO DR 0
<S,G,RPT> Prune option was added in ExtremeXOS 15.7.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
